combining the results
I recently had to calculate maximum moment for different load combinations (entire beam and alternative spans) to find the worst case. Is there any way of combining the results into one diagram? Ideally, I need a graph which will show 39.31(first photo) at the first span and 42.36 at the support(second phot). Is there a smart way of doing this?
Many thanks,
Kasia
Artur.Kosakowski
Autodesk Support
Autodesk Support
To create the graphical display of results (envelope) for many load cases select them (type their numbers) in the load case selection field (the one where you have case 3 selected on your screen capture). You can also select the predefined Combinations filter.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Thank you!
