Combinations and envelops
ypsilspy
ypsilspy
I've made the design of a connection and as I can see from the forces in the node of the selected connection, robot takes in account only these from a common combination, so it doesn't solve the connection with the envelope of forces in this node. So, it doesn't take in account the max-min for each (N, My,Mz,Vy,Vz) from all combinations to design? Is that right?
Thank you in advance.
Romanich
Hi @ypsilspy,
I would recommend to filter/collect and analyze loads by yourself and then use the worst cases with manual input.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Mohammed_Ata
@ypsilspy
I think what you have listed is not reliable ! We, as STR. designers, don't take the max each straining actions from all combinations! It is so fictitious!
We regularly design according to all combinations, then take the combination that give us the maximum section at the end ! Not collect the max N and the Max M and the Max Q and so on !
If We have
Comb 1: M=20 t.m , N= 30t
Comb 2: M = 15 t.m, N= 40t
We don't design on M=20t.m and N=40t, because this is not reliable !
You can group all of combinations and RSA can design according to all of them and give you the relevant section, see the tutorial below.
ypsilspy
So, Mohammed you don't accept the design with the maximum and minimum forces acting on a member.In the tutorial you've post, we can see the way we can make this envelope, but why to do this if you don't use it for the design?Furthermore, why Robot gives to the results table the max and min N,Q,M for every single mumber from all the combinations?
Also, I have to mention that other programms make design with envelops, such as Sofistik, with the module "Maxima".
However, thanks a lot for your concern to answer to my question.
