Hi.
I have a steel structure almost like a frame on top of concrete columns. To connect the bottom of two steel columns to my top concrete column I've used rigid links and released (pinned) the bottom of the steel columns. Rigid links are also applied to the walls for interaction between concrete column and wall.
With these boundry conditions I get an instability in node 56 UX direction. This is with DSC on. With it off I do not get the instability issue, but my deflections are displayed kind of weird so I think something is wrong.
Loads are applied in both steel and concrete structures.
The file can be downloaded through the dropbox link:
https://www.dropbox.com/s/yqx12bom93ezk4l/Shaft%20transformer%20substation.rtd
Here's a simplified model where it works like I want and I'm not getting error or weird deflections.
https://www.dropbox.com/s/mxkraex6vy4m17n/Test.rtd
