Columns and rigid links
Grohl
Message 1 of 8
Grohl
Hi.
I have a steel structure almost like a frame on top of concrete columns. To connect the bottom of two steel columns to my top concrete column I've used rigid links and released (pinned) the bottom of the steel columns. Rigid links are also applied to the walls for interaction between concrete column and wall.
With these boundry conditions I get an instability in node 56 UX direction. This is with DSC on. With it off I do not get the instability issue, but my deflections are displayed kind of weird so I think something is wrong.
Loads are applied in both steel and concrete structures.
The file can be downloaded through the dropbox link:
https://www.dropbox.com/s/yqx12bom93ezk4l/Shaft%20transformer%20substation.rtd
Here's a simplified model where it works like I want and I'm not getting error or weird deflections.
https://www.dropbox.com/s/mxkraex6vy4m17n/Test.rtd
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check defnition of releases at the bottom of frame legs.
Rafal Gaweda
Message 3 of 8
Grohl
Frame legs pinned in bottom. I want rotation allowed.
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
So everything is correct unless you show me this "weird diagram".
You can not compare results between models with and without releases at legs. They are different because of releases.
Rafal Gaweda
Message 5 of 8
Grohl
Thanks for reply!
Please look at attachments. Same releases in legs. Much smoother without the whole strucure.
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
You are comparing FE maps deformation diagram with Bars deformation diagram.
(Deformation for FEs just displays deformation basing only on displaced nodes)
Rafal Gaweda
Message 7 of 8
Grohl
Thanks!
But, the issue with node (56) instability type 3 still bothers me. Any thoughts on that?
And, is the way I've connected the wall with the concrete column with the frame an appropiate way to do it?
Thank you again.
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
