Column splice Connection
Message 1 of 8
When I select the columns on my structure to design a splice connection,  it suggests a beam-to-beam connection instead (when I select 'new connection for selected bars'). Does anyone know the reason behind this?
Thanks in advance
Kyri
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the model with these two columns?
Artur Kosakowski
Message 3 of 8
Hi Artur,
I am sending a link for you to download the model since it doesn't let me attach it directly here.
https://we.tl/t-aagWoz69RB
Kyri
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to change the connection type in this way:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 8
Hi Artur and thank you for the response. Please see the attached picture. The option for the column splice is not available. Only the beam splice is available.
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you check on the current version of Robot?
Artur Kosakowski
Message 7 of 8
Hi Artur,
It's RSAPRO 2016
Kyriakos
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I actually meant that you checked the same on RSA 2019 🙂
Artur Kosakowski
