Column lateral torsional buckling
Hey guys i have a column and a wall which is concrete. However I'm not sure about how to model it in the lateral buckling option.
And in case it wasn't concrete but instead wood purlins pr 1070 meter then what to do in that case?
Thanks in advance.
Here is the robot file.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You may want to use the internal bracing option and provide restrains at the points where the purlins are located. If the beam is defined along the wall and fastened to it along its length you may consider disabling it entirely.
Artur Kosakowski
with wood purlins it's restrained both at the upperflange and bottom flange`?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The one where the purlin is located at.
Artur Kosakowski
