Column axial stiffness
How to increase the axial stiffness of the concrete column section ? There is only an increase or decrease the section for the moment of inertia !
Thanks in advance,
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may try to increase the value of Young modulus in the material assigned to this column (and decrease moments of inertia) or define the section bu its properties and assign concrete material to it.
Artur Kosakowski
