Column and Beam Reinforcement
tayob09
tayob09
Dear Structural Engineers & Autodesk Robot Analysis Professional Users,
I am facing a big challenge with my model. Unsatisfactory load capacity of the column is the message that I am getting. I am changing the cross section up to 1000 x 1000 mm and still getting the same message. This can not be possible to get a cross section of Column 1000 x 1000 mm in the model.
I have attached the file.
May you help me to fix out the problem.
Screenshot 01-29-2019 16.48.13.pngScreenshot 01-29-2019 16.50.33.pngScreenshot 01-29-2019 16.51.11.png
Hey
The RSA model is not attached in your post, only pictures.
Initial ideas is:
- Have you checked nodes are aligning?
- Have you by accident added load/moment to the column?
- What happens if you just delete the coloum and reinsert it? maybe change to steelsection and test.
- Have you specificed a very low concrete strength?
tayob09
Dear All,
May you find the attached file according to my request.
Hi
I'm almost sure that you have wrong loading value!!
Your reactionforces are insanely high, millions of kN!.
As i can see you are applying forces on planer in kN/mm2 not m2.
