It is possible to contain the range of values to obtain a mapping with multiple colors?
In my case I have a solid that has small points of high stress values and the mapping is only one color.
I tried to put the values of range , but Robot considers the whole range automatically calculated.
thanks
Solved by rsousa_. Go to Solution.
iN your case I guess set properly Max value - > remember to unmark "con normalizzazione" checkbox
Andrea
From my curiosity, could you be so kind and send me this model to look at?
Andrea,
Goto scale tab, and change the user limits and division to get what you want. And before hit apply change the scale type selection to "user-defined". Then hit apply and voilá!
Regards
Thanks to all!
Rafal I am attaching the link to the file: http://we.tl/Q6ADCjZGqT
It is the upper part of a pillar inclined, which will be bolted to the truss.
I carry out the verification with the efforts of Mises.
Hello
