Cladding load distribution RSA2023
max
max
The load distribution on cladding has lost the "One-way"option, currently only "Two-way" being available. Model attached.
Please help.
Thanks.
EduardoMeruvia
Hi @max ,
Cladding option to change distribution appears okay in my end, see image below.
max
Thank you Eduardo.
Is there an option for "One-way" at your end?
"One-way" not available on my machine.
cheers
EduardoMeruvia
@max, one way option shows to be there on my end also. See below.
EduardoMeruvia
maybe try opening a copy of your Robot file as "Repair Mode"
max
Thank you very much. Repair mode did the trick.
cheers
max
Hi Eduardo ( @EduardoMeruvia )
Opening the file in Repair Mode did the trick.
Thank you very much for your help.
Max
