Cladding load distribution regions area counting
wangjue1990
wangjue1990
Hello, guys.
question 1>
so in the picture, the load were correctly distributed in the different color zone.
But I want to know the exact different color areas, is that possible in Robot to check?
for example how do I get the area of grey, red, purple, blue color area?
question 2>
and this load distribution I can only see if I have a cladding,
what if I have a panel(for example 400mm thickness concete slab), how do I get this panel to show the same color load distribution regions?
Your reply woule be really appreciated!
B R
Jue
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @wangjue1990
question 1>
Such areas are not displayed (as values) in Robot.
question 2>
If you assign it the calculation model with this type of load distribution then they will be shown
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
wangjue1990
Thanks for the quick reply.
Just one more following question for your answer to question 1:
is there a way to show the area with value? by some macro?
B R
Jue
