Dear Sir, I'm Facing the problem in Circular Tank Design.
i can draw the circular shape of a wall and after i applied Hydro static Pressure and Created the manual combinations of ULS and SLS. Added the panels to the code parameters in the required reinforcement of walls and Calculations also done. After the calculation by picking the panel and go to the provided reinforcement of RC elements its showing the notification like indicated objects must be laying in the same plane. its not showing the wall reinforcement design panel instead of its showing the slab reinforcement design panel. And its considering it as slab. Thank You
Solved by Krzysztof_Wasik. Go to Solution.
Hi @Anonymous
Provided reinforcement module in Robot Analysis can be used for flat panels only. You can calculate reinforcement for flat slabs and walls. Curved panels cannot be transferred to provided reinforcement module. For curved panels only required reinforcement can be calculated
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
