Circle geometry
Circle geometry
Circle geometry
hello,
I am new in this software
I Want to import a complex geometry (with dxf file) which include a curved beam (a ring ) but the robot remove it.
Is there this ability to the robot fem?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Thanks for the reply
unfortunately this doesn't solve my problem
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dxf file please
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
becase this dxf does not contain lines \ polylines, only blocks and solids
To open file
- explode all blocks in ACAD
- export is as *.sat file
- enable ACIS (solid modeler) before you open sat file (or attached rtd file) in Robot
Good luck because I do not understand what to you want to do with it in Robot
Edited by
Discussion_Admin at users request
Rafal Gaweda
Thanks a lot
