hi,everybody
i am from china, I want to know that will chinese code be included in robot 2015?
Hi. Chinese steel, Australian code and I have that warning:
The members 1 are made of materials from the database in which all properties are defined as DESIGN values. The currently-set code requires using characteristic values. It may lead to unneeded underestimation of member resistance. It is recommended to change the material so that it comes from an arbitrary database except for: RMAT048 (Polish materials), RMAT070 (Russian materials) , RMAT086 (Chinese materials).
I know that I can change resistance to "Characteristic", but I wish to have proper material properties without any hassle.
The best solution would be to manually add Chinese steels you want to use in your model to Australian material database and set it as active in Job Preferences. The point is that the definition of the material properties should correspond to the 'exopectations' of the selected design code.
