check panel dimensions
pics.munmun
pics.munmun
Rafacascudo
I use the copy/move tool .Click on a corner ,then move(without clicking) to the side corners or the diagonal corner. Check the vector values on the tool dialog window
Rafael Medeiros
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @pics.munmun
For quick dimension check you can use the following option
Krzysztof Wasik
