model problem
model problem
antonino.gulletta
Message 1 of 10
model problem
antonino.gulletta
Dear all,
I have to model a curtain wall on Robot and subject it to some loads in order to verify its structural strength. I modeled transoms and uprights as beams and columns, while glass as a panel. When I go to insert loads and launch the analysis I don't get any displacements. While removing the panel everything works. What could be the problem?
Thx for your attention
Replies (9)
Message 2 of 10
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @antonino.gulletta
You might use rigid diaphragm for panel calculation model. Screenshot does not provide necessary information to detect problem. Share your model for verification.
Krzysztof Wasik
Message 3 of 10
antonino.gulletta
Thx,
I have attached the model
Message 4 of 10
Krzysztof_Wasik
Autodesk Support
Autodesk Support
You have used XY diaphgram for vertical panel. It is not correct calculation model definition for vertical panel (it can be used for horizontal panels - program shows error while calculation).
Define model in XY plane (rotate it and modify loads) or remove diaphragm from calculation model guscio2
Krzysztof Wasik
Message 5 of 10
antonino.gulletta
I entered the diaphragm when I read his suggestion. Even without it the model doesn't work.
Message 6 of 10
Krzysztof_Wasik
Autodesk Support
Autodesk Support
With calculation model guscio (no diaphragm) I am obtaining displacements for load case 1 (other load cases have no loads defined).
Displacements are small probably due to excessive panel thickenss (50 cm).
Krzysztof Wasik
Message 7 of 10
antonino.gulletta
I'm doing something wrong. I see the deformed, but the displacements are zero.
Message 8 of 10
Romanich
Hi @antonino.gulletta ,
Please check the units and number of digits after the decimal point.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 9 of 10
antonino.gulletta
Could it be that the program approximates to a certain number of decimal places? and being small displacements do not result? If so, where can I change this property from?
Message 10 of 10
Romanich
From menu Tools - Job Preferences
Roman Zhelezniak
