Check if the sum of resistances of columns is greater than the beams
mjoflor
mjoflor
How can i check the next
 check if the sum of resistances of columns is greater than the sum of resistances of beams (increased by the coefficient g)
thanks
@mjoflor I edited the topic from 'Check if the sum of resistances of columnns'  for better findability and marked posts as the solutions. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution. Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check
http://docs.autodesk.com/RSAPRO/2014/ENU/filesROBOT/GUID-25441D9E-85F9-4F15-9726-6072E76845CA.htm
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
mjoflor
Ok thanks but do you post a example please????
Artur.Kosakowski
Autodesk Support
Autodesk Support
Here you are.
Artur Kosakowski
mjoflor
thanks for all
Hi @Artur.Kosakowski  @mjoflor
I have read the linked that you have posted regarding weak beams - strong columns.
I am trying to find out the window of "Node Geometry" in order to carry out the check but I can not find it.
I have change the designed codes to ACI and EC2 but I can not locate the "Definition in the Beam-column nodes module".
Could you please guid me how to access it?
Thank you very much.
