- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I'm currently working on a script, that needs to check if a node in my model has a support applied and also to check the name of the support.
I found a example code which uses the call HasLabel.
This is how i implemented it in my code:
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReferenceToFileAndPath(user +r"\Dynamo\Dynamo Core\1.3\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
from RobotOM import *
from System import Object
#The inputs to this node will be stored as a list in the IN variables.
Sup_nodes = IN[0]
SUP_LAB = IN[1]
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
ProjectPrefs = project.Preferences
bars = structure.Bars
node = IRobotNode
node_col = structure.Selections.Get(IRobotObjectType.I_OT_NODE)
node_col = project.Structure.Nodes.Get("22")
node = node_col
if node.HasLabel(IRobotLabelType.I_LT_SUPPORT):
OUT = "Support aanwezig"
if node.HasLabel(IRobotLabelType.I_LT_SUPPORT,"2.705NAP"):
OUT = "Support en label aanwezig"
When running this script the first if statement returns "Support aanwezig". works perfect.
but on the second if statement i get the error "Traceback (most recent call last):
File "<string>", line 33, in <module>
StandardError: Error while invoking HasLabel."
Does anyone know how to check also if the label is applied?
@Rafal.Gaweda @cool.stuff @jokiller70
Thanks in advance
ps: what i want to achieve with this function is to speed up a 'brute force search' model. because know the script is overwriting the nodesupports in all runs, while there are only some small changes.
Gr Edward
files are attached.
