Change type of analysis
rodainnajjar1229
rodainnajjar1229
Dear all
Kindly  find  attached  file ,robot model  I have  to change  type of analysis  from nonlinear  to linear  ,but I have no loads in case dialog  in automatic combination ,pleas help
thanks
Artur.Kosakowski
Autodesk Support
Autodesk Support
For linear static you cannot set cases that you want to use in definition of a combination as auxiliary.
Artur Kosakowski
rodainnajjar1229
dear sir
i apply your suggestions , but model calcolation nonlinear anlysisi
kindly find attached file
rodainnajjar1229
dear sir
Artur.Kosakowski
Autodesk Support
Autodesk Support
This is due to unidirectional boundary conditions you defined.
Artur Kosakowski
