Change Node Numbers
Change Node Numbers
PaulGrimes2282
Change Node Numbers
PaulGrimes2282
Is there any way to change the number assigned to a node? I have a spreadsheet designed to input all of my nodal data by cutting and pasting, but a couple of nodes are no longer correctly numbered for the spreadsheet and it mucks everything up.
For example i have a node numbered 86 in the model, with bars and properties attached, that i would like to be numbered 175. Is it possible without recreating the node and all the bars attached to it?
thanks!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
PaulGrimes2282
thanks!
