Cannot find Robot Structural Analysis 2023 SDK
Williamsdg7
Williamsdg7
The question says it all.
I've searched the forum for where to find the SDK and found this post here:
"SDK package needs to be installed:
  1. Browse to C:\Autodesk\WI\Autodesk Robot Structural Analysis Professional 20xx\x64\Tools\RSASDK.
  2. Run RSA_SDK.msi.
  3. Browse to C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 20xx\SDK where SDK has been installed to look at the API documents."
However, when I look for the folders, I'm noticing the folder for Robot is not present in C:\\Autodesk\, Has the SDK location moved for the 2023 version?
okapawal
Hi @Williamsdg7
Starting from version 2023 and use of web installer, SDK is installed by default in Robot directory:
"C:\Program Files\Autodesk\Robot Structural Analysis Professional 2023\SDK"
Waldemar Okapa
Sr Product Owner
PABLO.SANCHEzZTKJ5
Hi @Williamsdg7 ,
I have this folder (point 3) when I installed the Robot 2023 in my computer.
I don't remember well, but when you are installing the Robot I think you have to activate an specifiq check box to confirm the SDK installation, maybe you forgot it.
Williamsdg7
I don't see that directory at all in the Autodesk folder
Williamsdg7
I do not see the folder for Robot in the Autodesk folder at all.
Williamsdg7
SDK found in the above accepted solution. Thank you.
okapawal
Basically it is in the folder where you installed Robot.
Providing that you didn't uncheck SDK component installation
Waldemar Okapa
Sr Product Owner
