Can robot generate all possible load arrangements
Hello
Does the robot strcutrual analysis makes for me all possible load arrangements, factored and unfactored
for eample if i have 2 spans beam i would have the following arrangements or cases:
Case 1 ) span 1 : factored load, span 2: factored load
Case 2) span 1 : unfactored load, span2: factored load
case 3) span1 : factored load, span2: unfactored load
let's say i have 4 span beam and i would like to draw BMD for all possible load cases
Replies (9)
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example for 3 spans
(live load cases correspond to each span load) ;  crucial is to set each LL case in separate Group.
Rafal Gaweda
thank you for replying
may I know the steps to generate that
I tried going to Loads>>Automatic combinations>>Manual combinations>> next, and i selected the cases that i need as shown
but the program will generate for the first combination all spans are factored ( 1.4DL + 1.6LL) which is fine
but for the second combination all the spans will have the following load (1DL), that's not excatly what I am looking for, I need the second combination to be for example first span (1DL) and second span (1.4DL + 1.6LL) as the BS 8810 code.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Hi
Do I have to create 3 cases with DL and 3 caes with LL?
for example
DL1 : load on span 1
DL2 : load only on span 2
LL1: load only on span 1
I created my load cases each on every span and created automatic load combination
but nothing happened
maybe I am doing it wrong
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have you run calculations?
Rafal Gaweda
thank you
May I know what does : and, or (incl), or(exlcl) mean?
Artur.Kosakowski
Autodesk Support
Autodesk Support
AND: (1 and 2) always together
OR (INCL) :1 or 2 or (1 and 2)
OR (EXCL):1 or 2 (never together)
Artur Kosakowski
