Can not put exact value of dead load in Frame Generator
Message 1 of 11
Replies (10)
Message 2 of 11
OK, I will try again...
My problems is that when I am designing frame in ROBOT 2015 frame generator I want to put dead load of 0.1 T/m2, when I am writting value it is been rounded to 0, f.e. when I am writing value of 5.5 its rounded to 6 T/m2. I am using United Kingdom as input language and have no problems when writting dimensions in the frame generator, there I can write values divided with comma.
Anyone was dealing with the same problem. Thank you for your answers.
Message 3 of 11
Rafacascudo
Tools/job preferences/units and formats/ force
set as many decimals as you want/need
Rafael Medeiros
Message 4 of 11
Like this? I have attached picture....
Checked couple of times but still get 0 instead of 0.1 T/m2
Message 5 of 11
Rafacascudo
How does it appear in the load table?
Rafael Medeiros
Message 6 of 11
Morning,
Attaching some pictures:
In the first picture value is written: 0.1  T/m2
In the second picture is the result after I push TAB or mouse and leave value window.
Message 7 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Start a new project and set the units of forces to T 0.12 as suggested by
2. Save the current parameters of Job Preferences as default
3. Generate a new frame (try with both comma and dot as separators).
Artur Kosakowski
Message 8 of 11
I go to Job Preferences and and force parameters was set to 0.21. Still, I saved it as default.
When I am generating new frame and set dead load 0.1 (with dot) I get 0, when I set dead load 0,1 (with comma) I get 1. Seems that dot rounds value and comma multiplies f.e. if I write values of 11,11 I get 1111 after I click TAB or mouse.
Maybe there any other Preferences in ROBOT where I can check value's precision?
Message 9 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is it the same after you rename your CfgUsr folder?
Artur Kosakowski
Message 10 of 11
Pawel.Pulak
Autodesk Support
Autodesk Support
I suppose you observe the effects as in this video:
The workaround is to increase the number of decimals for Reinforcement Areas from zero to 1 or 2. Don't ask my why this specific one and what is the relation between reinforcement area units and load units - it needs to be investigated and fixed 🙂
Additionally after setting the units and number of decimals it is recommended to use in Job Preferences the button "Save current parameters as default" - because Frame Generator starts a new project with default Job Preferences.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Regards
Pawel Pulak
Technical Account Specialist
Message 11 of 11
Wonderful =]
Thank you very much for your support. It worked!
