Calculation Notes mass+complec column
JPNR87
JPNR87
under Analysis-Calculation notes-simplified Note structure MASS is presented.
I have complex columns with batten welded plates. Doest program count those batten plates to total mass?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @JPNR87
No, it doesn't . The same for welds, bolts, ribs etc.
You may consider using the additional factor for self-weight load to account for them if required.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
