Cable structure no convergence
saraingenieur
saraingenieur
Hello everyone!
please i need a help.
I have stumbled on a question regarding the cable structures.
I keep getting the "no convergence of nonlinear problem" error.
Thank you in advance.
Simau
@saraingenieur
Case N°1 is not correct as there is self weight and other loads?
Wind loads cases have to be set as auxiliary
Create combinations with selfweight and wind case
Structure is not stable in Y direction, you need to add some other cables
set Non linear parameter as in the screenshot below
Model attached
M. Agayr
saraingenieur
thank you
