Building Sway Lateral Wind Results
Hi Guys
Would like your advice here. I've got a 40+ storey building right now that I've modelled in Robot.
In particular I'd like to look at a relatively accurate building sway figure for wind lateral wind load. I've run my model in RSA and its giving values in the order of 180mm; however I've run an equivalent test in Etabs which is giving values in the order of 500mm. In both models I've reduced the Ig to 0.35Ig.
In Robot, editing the Ig value didn't seem to make a difference for sway which is very strange; as I still got values of 180mm where as I would of expected it to change significantly.
Grateful if someone can assist. I've attached the model here for reference. I'm trying to model the columns as pin-pin and using the core walls for lateral stability. The floors are modelled as rigid diaphragms except L2 which is a transfer plate and modelled as a shell.
My main question is as follows:
1. Have I reduced the Ig values correctly in the model?
2. Am I modelling it correct/feedback would be great.
3. Tips and tricks to get Robot to give accurate sway values?
Cheers
Jim
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'd suggest running a smaller scale model first so that it is easier to compare results after making a change to some parameters as working with 40 story building to determine the correct way of modelling it may not be that easy. First of all by reduction  of Ig in ETABS do you mean out if the wall plane stiffness  or in-plane stiffness? Perhaps you should define a cantilever build from panels defined one above another and compare displacements for such simplified model first?
Artur Kosakowski
Thanks for the reply Arthur
Im referring to both in plane and out of plane stiffness reduction.
I've realised my problem is to do with having to modify the property of my core walls under the  'Orthotropic' tab.
In Etabs; I've got f11,f12, f22 =0.35. m11, m12, m22 =0.35 also (will reduce out of plane bending later if Im getting too high results).
In Robot, I've tried to do the same: f11,f12, f22 =0.35. m11, m12, m22 =0.35. I assume they relate to the same factors for Etabs. (I want to reduce the in-plane and out of plane stiffness)
I've tried to run a test model and now I'm getting instability within the mesh nodes.
Can you assist? Grateful for your thoughts.
Jimy
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please watch Robot webinar 16 (the recording is available from http://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-webinars/td-...) and focus on the slide 21 Smiley Wink
I'd suggest setting the direction of the orthotropy for walls as Direction Z Smiley Happy
Artur Kosakowski
Thanks Arthur.
James
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
