Hi everyone,
I am trying to verify a funny shaped / ground supported slab under compression and would like to seek advice.
My problem is as follows:
A secant pile wall will be used to allow the installation of a new manifold in X city.
The secant pile wall will be propped at multiple level just like this :
My task is to make sure the propping system will work.
No problem to check the steel props. But the secant pile wall designer assumed that the secant pile wall will also be propped by a 200mm thick RC slab at the very bottom of the excavation.
I need to check that the slab can take the compression and will not buckle.
My model is the exact shape of the slab using 'parameters of foundation elasticity' for support (uplift Z) with a load all around its perimeter. See below:
I have performed a buckling analysis and read the critical coefficients for the first 10 modes.
First of all, I'd like to know if there is a better way to check this slab. As the buckling analysis do not take into account any imperfections, this model don't represent the reality.
Have a good day,
Mathias.
