Global extremes of reactions
Lembartassimas
Lembartassimas
is there a posibility, to see absolute extremes of reactions, not - smallest one and + biggest one.
For example - Fx are -4, -2, 1, 2, 3, so in robot global extremes tabs MAX would be 3 and MIN would be -4, but to design foundations, i need to have smallest - 1 kN and biggest -4 (as long as - and + only shows direction).
Thanks.
Muhammed.OPERA
Hi @Lembartassimas
If you wanna do that, you can import reactions values using Results Connect in Excel.
Then with a simple function convert them to the absolute values (using Abs(cell no.) function).
Then in a cell use Max. or Min. function to get the max or min. of the absolute values.
And this is a simple screencast showing how to import reactions in Excel using Results Connect:
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Lembartassimas
It should be enough to use filters two times:
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
