Buckling Analysis
Buckling Analysis
faisal.aaouatif
Buckling Analysis
faisal.aaouatif
Good Morning , Evening
By reading some topics about the way RSA analyses the buckling stability of a structure , i raises some questions :
1. how can we define a manual combinaison to a load case in order to use for as buckling analysis ?
2.Is it "suffisant" to say that if all the critical coefficients, for the load case on which the buckling analysis is based, are greater than 1 that there is no problem of loss of stability ( for this load case) ?
Thank you
Rafal.Gaweda
Autodesk Support
Autodesk Support
In normal way or this type of combination:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Buckling-combination/td-p/4331271
Yes
Rafal Gaweda
faisal.aaouatif
Thank you Rafal
