Buckling analysis
Buckling analysis
MohammadZaman
Buckling analysis
MohammadZaman
Hi
I modeled a simple steel column to verify the Euler  critical force.
But I couldn't understand the results?  There is a difference between program calculation and Euler formula.
What's the mining of  critical coef.
I have attached a picture.
Artur.Kosakowski
Autodesk Support
Autodesk Support
This is the value by which you should multiply the applied load to obtain the value of the critical load (load level that causes the structure to loose its overall stability).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
