Brazilian codes in Autodesk Robot
Message 1 of 76
Hello everybody.
The Brazilian codes (NBR 6118 for concrete, and NBR 8800 for steel) are not present in Robot. Is there a plan for them to be included?
What do you do when you’re working in projects for Brazil?
I’m sorry if this question has been answered before, but I did a search and found only one topic, that doesn’t directly answer this question.
Thank you all.
Ricardo Duarte, Eng.
Replies (75)
Message 61 of 76
Rafacascudo
Thank you Stefano for your kind words. But I would rather be doing some  "boring" conventional buildings and having a fixed enginnerring job than being the author of many of the well known structures in Brasil and having "nothing".
Right now , it´s 14 months unemployed and counting...Smiley SadSmiley Sad
But let´s talk about good things. I think ,there should be a place here in the forum (fixed thread maybe) where the users could post/submit interesting models done in Robot  so others could "borrow" ideas when doing similar projects.
Some more interesting models ,now from Oscar Niemeyer , brazilian Archictet , author of many well known and beautiful constructions in Brasilia and around the world.
Rafael Medeiros
Message 62 of 76
LeeCastro
Aproveite e aprove a idéia
https://forums.autodesk.com/t5/robot-structural-analysis-ideas/brazilian-codes-in-autodesk-robot-old...
Marque Aceitar como Solução e clique em Curtir.
Select Accept as Solution and click on Like
Li Chong Lee, DSc.
LinkedIn Instagram | Facebook | Twitter  | YouTube
Participante da Comunidade de Usuários Autodesk Brasil
Message 63 of 76
Senhores,
Já fiz alguns treinamentos do Robot, mas em todos eles os exemplos são dados com lajes maciças. Já sabemos que esse tipo de laje já não é a mais vantajosa em termos financeiros. Aqui na minha cidade usam muito lajes pré fabricadas com vigotas treliçadas e protendidas. Infelizmente o Robot não tem essas lajes disponíveis na biblioteca, nem mesmo as nervuradas com cubetas. O que o senhores me dizem sobre esse assunto?
Message 64 of 76
rogerscapini
O método mais simples é: NÃO USE O ROBOT para projetos no Brasil. A Autodesk simplesmente não se importa com a nossa norma.
Já gastei 30 mil reais com outros programas brasileiros que me atendem em praticamente tudo que o Robot promete dentro do meu escopo. Com a grande vantagem que não preciso comprar outro programa para gerar os detalhamentos.
Palavra de honra: eu teria comprado o Robot sem pestanejar, se não fossem esses problemas de norma e detalhamentos.
Com a palavra, a Autodesk.
Message 65 of 76
LeeCastro
Olá,
Ainda não entrando no assunto do que ele pode fazer em auxilio à NBR (por que ele não é nativo ao ROBOT) agora se você assinar o pacote subscription de 1 ano do AEC...aquele que vem o revit, autocad, civil3d e demais o robot, o bridge e o dynamo estão vindo neste pacote!!!  Então se vc assina esse pacote vira o robot.
Li Chong Lee, DSc.
Message 66 of 76
LeeCastro
Ontem no AU2017
Projeto estrutural no Robot - um caso Real
Data de início: Terça, 19 Setembro, 2017 | Hora de início: 2:00 PM | hora de término: 3:00 PM | Grupo de indústria: Arquitetura. Engenharia e Construção | Produto principal: Robot Structural Analysis | Speakers: Gustavo Vasconcellos
Mostrar um cálculo estrutural real desenvolvido no Autodesk Robot.
Roteiro: AUBR13
Li Chong Lee, DSc.
Message 67 of 76
What ??? Rafacascudo didn't do that projects.
Here are the real autors:
- "Ponte JK" was projected by Mario Jaime dos Reis Vilaverde
- "Cidade das Artes" by Bruno Contarini,Carlos Fragelli and Portzamparc
- "Museu de artes do Rio de Janeiro" by Bruno Contarini
Message 68 of 76
Rafacascudo
Really???
Do you think that just 1 or 2 people can do huge projects like those all alone?
Mario , Bruno , Fragelli together with Jose Viĺas boas and Sussekind were partners on a very inovative design company called Projectum. Back on the 80s Projectum was absorbed by the huge Promon engenharia where I was already working as a junior engineer.
Some of them continued working for Promon and some like Bruno and Mario didn't.
They were all around 30 years older than me.
So , they had no abilities with computers by then and also nowadays . Since then I was also their computer guy. And on the 80s we are talking about the pre-historical age of structural engineering programs using perforated cards as input . Later ,input lines could be recorded on tape to be carried to a larger mainframe computer outside the firm. Computers at that time could take a whole space of a small building.
Over all these years I have done projects with all of them , but very mostly with Carlos Frageĺli .
Mario a brilliant engineer who has passed away some years ago ,around 2001 he got the Ponte JK project to his firm Projconsult .But he had no expertise to do the computer model and also not enough people to design it. So he asked Fragelli and I , that were on another firm , to help him. That's when we 1st purchased Robot Millenium to perform the dynamic analysis.
Bruno and Fragelli are still alive and I can give you their contacts if you desire to check this any futher.
By the way , Bruno is a wonderful engineer and has done some nice designs like the Museu de arte moderna de Niteroi. I have done for him some interesting projects like the new FGV building( Oscar Niemeyer) dynamic analysis .
But he didn't work on Ponte Jk or Cidade da musica executive projects.
And also Christian de Portzamparc is a world famous french ARCHITECT who did the plans for cidade da musica . But Not the design. He couldn't even try because there was no Revit by then...😆😆
Rafael Medeiros
Message 69 of 76
If its true and you are so good as you are saying why are you unemployed ? why don't open your own office ?
Even I have my own office here and get some money with it.
Message 70 of 76
gustavo_c_vasconcellos
Renan,
I didn't know why you were so unpolite!
I would like to remind you that here is a Forum to discuss about Robot and not a place to offend or discuss with others.
Gustavo
Message 71 of 76
StefanoPasquini6790
Renan,
the forum is a place where the community try to solve the problems of the new members, and it works only with kindness of the one that spend their time to explane the solutions.
Rafael is one of the most gentle and precious members of this RSA forum, he have a curriculum and a skill that probably you can only dream, why don't you share your projects in Robot Art Gallery? We are really courious to see your skill!
Without the kindness and knowledge of people like Rafael the forum will die in a while....Artur, Rafal and Pawel are the most important people in this community, but they can't manage all the threads, so they need and deserve to be helped!
I can assure you that you will never receive help by me, respect is the first step in a community and you forgot it!
I'm sorry, but this is my tought!
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 72 of 76
Meus caros, vocês já ouviram falar do curso do EngenhaBim para parametrização do Robot segundo a 6118?
Se sim, o que acham a respeito?
Eu estou fazendo este curso nesse exato momento e tenho sentido que é de grande ajuda.
Sou estudante de engenharia civil e quero, futuramente, entrar na área de cálculo estrutural.
Cheers
Abraço!
Message 73 of 76
nt_170
Observer
Observer
Fiz o curso e não é grande coisa, ele ensina basicamente adequar materiais... mas em termos de cálculo estrutural não é adequado a norma...
Cheers
Abraço
Cheers
Abraço
Message 74 of 76
Bom dia,
Você tem razão, não é totalmente adequado a norma, mas é praticamente tudo o que se pode fazer dentro do próprio Robot sem soluções voltadas a API ou verificações adicionais. Exatamente da forma que o curso é divulgado.
Esta limitação é do próprio software e com relação a API o suporte da Autodesk deixou bastante a desejar, pois sempre que solicitamos informações adicionais para melhorar a adequação não tivemos retorno.
Abs!
Message 75 of 76
 NBR 6118/2014 especifico no item 13.2.2, que a largura mínima (bw) da seção das vigas deve ser de 12cm (15cm para vigas-parede). Em situações excepcionais, essa medida pode ser reduzida para até 10cm. Recomenda-se a leitura dos trechos das normas que abordam essa possibilidade (NBR 6118).
Message 76 of 76
 NBR 6118/2014 especifica no item 13.2.2, que a largura mínima (bw) da seção das vigas deve ser de 12cm (15cm para vigas-parede). Em situações excepcionais, essa medida pode ser reduzida para até 10cm. Recomenda-se a leitura dos trechos das normas que abordam essa possibilidade.
