BIG PROBLEM IN CODE CHECK OF BARS
StefanoPasquini6790
Advisor Advisor
Message 1 of 22
StefanoPasquini6790
Hi everyone,
I absolutely need to understand if Robot had a bar-limit in verification of steel members.
Well, I try to explane my problem. I have a very big model with 86367 nodes, 84913 bars and 1778 panels
Well, when the calculation is done I run the verification of the bars to define the reliability intervention on the whole structure. This morning I've discovered this surprising bug....
When I run verification for whole bars I have a complete table with the list of the non verificated ones...I've ordered this table by the verification ratio and, for the same bar that have the maximum ratio I've run the verification again.
My big big Surprise is that the value of the internal forces are very different, and in case of one bar verification this bar is ok otherwise in case of multiple verification this bar is absolutely wrong.
Well, my question is: IS THERE A LIMIT FOR THE NUMBER OF THE BARS IN VERIFICATION LIST? I need a very urgent answer to this question to define how I have to go on with this project and to chek the real quality of the work just done!!
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Replies (21)
Message 21 of 22
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Stefano,
Have you managed to sort this issue out?
Artur Kosakowski
Message 22 of 22
StefanoPasquini6790
Hi Artur, no, I don't...but recovering and checking....and so on....I've solved the project.
Thank you so much for your commitment and see you in next posts.
PasProStudio
