Bending moment
Bending moment
Message 1 of 13
Bending moment
Hi everyone, I have one problem with my bending moment on this building, could you explain me how to solve this problem ? I attached the rtf file and the image of the problem. Thanks a lot for the answer
Replies (12)
Message 2 of 13
Message 3 of 13
http://www.noelshack.com/2016-49-1480957278-problem.png Click on this file, because i can't send the image
Message 4 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach rtd file with the model and tell which load case or combination to display deformation for please?
Artur Kosakowski
Message 5 of 13
I have problem to upload the structure, did you have one email to send you my structure on robot ? please Thanks
Message 6 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Message 7 of 13
Ok, i upload on mediafire : http://www.mediafire.com/file/hb8pktjs7tiaira/DM-Structure.rar (the link for download) I have also problem with the bending moment My. The combination is ELU which represent all loads. Can you send me what did you obtain for the moment y ? If I had the same Thanks a lot
Message 8 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 9 of 13
Why you select ELS+ ? I thing you should select ELU ? because its the combination of the load
Message 10 of 13
Why you select ULS + ?
Message 11 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
ULS+ or ULS - displays the envelope of the values (maximal and minimal at the same time) whereas ULS currently selected component and allows you to switch among the components. You can decide what you want to see but in all situations the Normalize button works in the same way.
Artur Kosakowski
Message 12 of 13
Then its better to choose ELS+ than ELU, because the els+ take more values ? I don't understand why we choose ELS+; thank you for explaining
Message 13 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
None of them is better or worse. Each display something different and it is for you to decide what you want to look at. ULS allows you to see the results for all components one by one whereas ULS+ or ULS- diagram shows all of them (the maximal and minimal envelopes) at the same time.
Artur Kosakowski
