Beam module vba
Beam module vba
Message 1 of 11
Beam module vba
Is it possible to add a beam directly into the beam module using vba?
By changing its dimensions of the beam by vba. Thank you for your help
Accepted solutions (3)
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
If I understood Your correctly, it can be done.
See example code below.
Dim Robapp As New RobotApplication
Dim RC As RobotProjectComponent
Set RC = Robapp.Project.ComponentMngr.Create(I_PCT_BEAM, "B1", "1")
Dim IRCB As IRConcrBeam
Set IRCB = RC.Data
IRCB.Geometry.SpanNumber = 2
Dim IBS As IRConcrBeamSegment
Set IBS = IRCB.Geometry.Span(1).segment(1)
IBS.Dim(I_BSD_BEAM_SECTION_DIM_H1) = 1
IBS.Dim(I_BSD_BEAM_SECTION_DIM_B) = 0.5
Set IBS = IRCB.Geometry.Span(2).segment(1)
Rafal Gaweda
Message 3 of 11
thank you very much it works!
is it possible to change the standard name of the beam P1, P2 ... in VBA?
Message 4 of 11
thank you your code is already complete.
Message 5 of 11
can you give an example to load the beam in the module beam in vba? thank you
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
HI @Anonymous
Example code
IRCB.LinearLoadsCount = 1
IRCB.LinearLoad(1).Case = 1
IRCB.LinearLoad(1).Nature = I_BLN_BEAM_NATURE_DEAD
IRCB.LinearLoad(1).Spans.Add 1
IRCB.LinearLoad(1).Spans.Add 2
IRCB.LinearLoad(1).Value1 = 1000
Rafal Gaweda
Message 7 of 11
Thank you very much it works perfectly. you master very well the engineering. i am satisfied.
Message 8 of 11
Photo.pngPhoto1.pngHello Mr. Rafal trying to customize the VBA code above I have not found a possibility to call in VBA for some buttons in images attached. Is it possible to do that in VBA? Thank you very much for helping me with an example.
Message 9 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Everything what is available by API you can find expanding IRCB in my code
Rafal Gaweda
Message 10 of 11
Hello Mr Rafal, yes I have already searched through your code. But it seems to be impossible to use the control buttons to frame in red on the image above in vba? Is there a vba guide for robot? thank you
Message 11 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
So it means it is not implemented in API.
Rafal Gaweda
