Beam fixed connection
antonio.lafuente
antonio.lafuente
Hi there
Is there a way to model a fixed beam connection? Something like the one below except that the column would be a wall to which the beam would be anchored? In other words something like a fixed column base connection but for a horizontal beam. any advice would be greatly appreciated
Thanks in advance
Antonio
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @antonio.lafuente
In this way:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
antonio.lafuente
Thanks Artur
I think this will force me to add stiffeners on both sides right? Could you anyway share with me the model?
Thanks in advance
Antonio
Artur.Kosakowski
Autodesk Support
Autodesk Support
Just a vertical panel and horizontal bar attached to a node of the mesh. As the connection type is a (column) base plate you would need to define tapered beam section as you cannot define brackets in this connection type.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
