beam and support wall or column
Message 1 of 9
I modeled a structure with walls and beams, the problem is that robot recognizes the beam supported on columns and not on the wall (when I go to the beam dimensioning module).
How to get the robot to take the wall as support for the beam?
Thank you
Replies (8)
Message 2 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @Anonymous
While beam transfer to RC Provided reinforcement module try to check if wall support can be activated.
Issue can be solved by dummy short column definition under beam support in supporting wall plane.
Krzysztof Wasik
Message 3 of 9
Hi
Message 4 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Just check on wall 28879 in support tab. Then it should be recognized as support.
Krzysztof Wasik
Message 5 of 9
In my exemple, 2885 is the number of the  slab(pannal5) and I want that the wall is the support of the beam.
Robot dont detect this
Message 6 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Please share your file for verification.
Krzysztof Wasik
Message 7 of 9
please see beam 1056 and wall number 1050
Message 8 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @Anonymous
You can select slab as support (it will have no influence on force distribution). In that case program will recognize support width 0.2 m (equal to slab thickness which can be modified afterwards)
Another solution - you can define in model dummy RC column with any section size (for instance reflecting required support width). Then support will be recognized automatically.
Krzysztof Wasik
Message 9 of 9
 thank you for the solution.
