I have generated nonlinear loadcombinations using this procedure:
However, I do not understand the presentation of the load combinations selected at menubar "Loads --> Combinations table". See attached picture:
Can someone please describe what has happend or advice me if I have done something wrong?
At the first glance it seems like you have 'replaced' load case numbers with load coefficients.
That is correct, something wrong happend when trying to generate load combintations. Problems solved.
