automatic combinations > manual combiantios - generate
memoalcr
memoalcr
I want to use the "automatic combinations > manual combiantios - generate" option but I can't follow the HELP provided.
Do you have an example using "automatic combinations > manual combiantios - generate"?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
memoalcr
After I open the LOADS>COMBINATION TABLE and I go to the Cases drop down menu, there is no LOAD COMBINATIONS option; only SIMPLE CASES and COMBINATIONS.
So when I select TABLE COLUMNS... the CODE COMBINATIONS COMPONENTS option is grayed out.
That was how far I got through the video
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
