Assigning Composite Section to Bars
Message 1 of 14
Hi ,
I was trying to model a composite section in robot. Just for testing I built a simply supported 10m beam to check if the reactions are correct under self weight.
This is the composite section i tried to model,
Weight of this beam is about = 158.3 kN/m - which should give me a reaction of 791.5 kN (for a 10m long simply supported beam)
Section Area: Depth = 4 m, Width = 1.4 m, A_total= 5.6 m2
Steel Plates (3 Nos): Depth = 1.3 m, Width = 0.1 m, A_steel = 0.39 m2
                    Area (m2)         Density (kN/m3)       Weight (kN/m)
Asteel           0.39                 78.5                        30.6
Aconcrete     5.21                 24.5                        127.6
I built this section is robot using,
Tools---->section builder (where i clearly specified the concrete and steel bits of the section).
I saved the section to database, and assigned to the bar
But in robot, i have to give the bar section a material property. So i assigned concrete to it and it gives a really high reaction (about 900kN).
How can i assign a single material property to a bar when it is composite seciton! every time i change the material (so the material i assigned during section definition is invalid). What is the use of defining a composite section then?
Can anyone help? and explain how to use section buider to define composite section and assign it to a bar? and get the correct behaviour?
Thanks and regards,
Vikas Venkatesha
Replies (13)
Message 2 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do not change the default material after defining a bar in a model as the weighted properties of the section are calculated for the material you selected while defining the section in the Section Builder module.
Artur Kosakowski
Message 3 of 14
Hi Thanks so much!
That is exactly what i need, but somehow my default material comes as ALUM,
Message 4 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you check if the information about the composite material is stored in the properties of this section?
Artur Kosakowski
Message 5 of 14
Hi Artur,
I checked the data base. It looks like you have eurocode in your preferences. I have british standards. Anyway i changed it eurocode and tried again now the default material comes as C60. I cheked the section database, i think its alright. Here is a screenshot.
Message 6 of 14
Finally i got the material right, but still wrong reactions. Its really confusing. Please help. If you want i can email u the model.
Message 7 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Send me both the model and your user section database. Thank you.
Artur Kosakowski
Message 8 of 14
Sent from my iPhone
Message 9 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
What about sending from a computer as no files were attached ? Smiley Happy
Artur Kosakowski
Message 10 of 14
Hi Artur,
This link has the model. I have attached it with the post or you can also find it in the following links.
https://www.dropbox.com/home/Robot%20Composite%20Section#
Kind Regards,
Vikas Venkatesha
Assistant Structural Engineer
D +852 3925 9739
[email protected]
Benaim
7th Floor Prosperity Millennia Plaza, 663 King’s Road, North Point, Hong Kong
T +852 2527 0233   F +852 2527 6364
An AECOM Company
Message 11 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you send your user section database file as well please? Thank you
Artur Kosakowski
Message 12 of 14
Please find the section user database attached as well
Message 13 of 14
Pawel.Pulak
Autodesk Support
Autodesk Support
Hi Vikas,
thank you for sending the file containing your user section database.
Looking into it and comparing with your model I have noticed that the composite section label used in your model was not up-to-date with the properties in the database. Probably in the meantime you have modified this section.
It was necessary to:
1/ temporarily change the section in the model to different one
2/ delete the outdated composite section label
3/ define new composite section label basing on your user section database
4/ assign new label to bar in the model
5/ run analysis
I have shown it in this viddeo:
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Message 14 of 14
Thanks so much Arthur. It was very helpful.
