applying load to panel
hi guys,
I need your help, I have this warning that "linear load has not been applied to a panel" what should I do and how do I do it to solve to problem for me to proceed on my design. see attached please
thanks for your effect.
Rafal.Gaweda
Autodesk Support
Autodesk Support
thanks. please I have attached the file now (zip). please look at it and tell met how to solve the problem or you do the correction and send it back to me.
thanks a lot.
Rafal.Gaweda
Autodesk Support
Autodesk Support
You need to check claddings coordinates \ panels meeting with claddings coordinates
For example claddings such as  2507 2511 2527 2531 (and similar) should have Y coord = 12,250000000
Check them \ correct them looking at  load case 8
You may use this:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/vba-excel-macro-for-any-object-geomet...
Rafal Gaweda
