(API) Storey Stability Index Calculation
Romanich
Mentor Mentor
Romanich
The calculation of the storey stability index Q is based on clause 10.14.4 of the National Standard of Canada CSA A23.3:19 “Design of concrete structures”. I hope this small macro will help Canadian Robot users.
General Usage Instructions
  1. Modify the moment of inertia for all structural members. It is recommended to use the IModifier to speed up the process.
  2. Make sure that storeys are defined in the model.
  3. Input manual load combination number in cell B2. It is assumed that the load combination contains lateral forces.
  4. Run analysis.
  5. Press the Get Results button.
Assumptions
For each storey Robot returns results in global X and Y directions. These results are reported in columns Vfx, Vfy, Δox, Δoy. However, for Q calculation the program uses the Square Root of the Sum of the Squares procedure to determine Vf and Δo.
Example:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
Autodesk Support
Autodesk Support
khimpitou
it would be appreciated if you make a short video clip for this, thanks.
Romanich
Hi @khimpitou,
Please check the video clip below:
(view in My Videos)
Roman Zhelezniak
