Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
(API) ROBOT / VBA: Activate or select load case
daniel_dcn
daniel_dcn
I'm creating a tool that inserts the load train into the model. First it creates the load case, then adds a set of nodal loads around some given node.
How can I present the results by selecting the new load case in the list?
Load train created with VBA. Case #15 is not being selected automatically.Load train created with VBA. Case #15 is not being selected automatically.
Thank you
Stephane.kapetanovic
hi @daniel_dcn
Sub Select_Load_Case15()
  Dim RobApp As IRobotApplication
  Dim ViewMngr As IRobotViewMngr
  Dim ActiveView As RobotView
  Dim CaseSel As RobotSelection
  Set RobApp = New RobotApplication
  Set ViewMngr = RobApp.Project.ViewMngr
  For i = 1 To ViewMngr.ViewCount
    If ViewMngr.GetView(i).Window.IsActive = -1 Then ActiveViewNumber = i: Exit For
  Next i
  Set ActiveView = ViewMngr.GetView(ActiveViewNumber)
  Set CaseSel = ActiveView.Selection.Get(I_OT_CASE)
      CaseSel.FromText "15"
  ViewMngr.Refresh
  Set RobApp = Nothing
End Sub
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
daniel_dcn
Thank you @Stephane.kapetanovic!
