(API) Reaction table configuration
lucasgiacomet
lucasgiacomet
Is is possible to activate the following option "For all objects" through the API?
Thank you.
Stephane.kapetanovic
Not exactly, the process via the API is to assign a full selection to the RobotTable.
Sub GetFullReactionTable()
  Dim Robapp As RobotApplication, rt As RobotTable
  Set Robapp = New RobotApplication
      Set rt = Robapp.Project.ViewMngr.CreateTable(I_TT_REACTIONS, I_TDT_DEFAULT)
          rt.Select I_ST_NODE, "ALL"
          rt.Select I_ST_CASE, "ALL"
  Set Robapp = Nothing
End Sub
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Even though it is implicit in the case of a reaction table, you can start from a dedicated selection to obtain the list of supported nodes.
  Dim supSel As RobotSelection
  Set supSel = Robapp.Project.Structure.Selections.CreatePredefined(I_PS_NODE_SUPPORTED)
  rt.Select I_ST_NODE, supSel.ToText
