(API) - Problem Selecting "Characteristics Points" on Panel Maps Results.
ducvanvt
ducvanvt
Hi
Is there a way to select the "Characteristic Points" on Panel Maps using API (see the attachment)? I already turn on "With descriptions" but could not find a way to access the Description Positions options. Can someone please help ?
Thanks a lot!!
Rafal.Gaweda
Autodesk Support
Autodesk Support
HI @ducvanvt
@ducvanvt wrote:
Hi
Hope this works:
viewRobot.ParamsDisplay.Set I_VDA_FE_CHARACTERISTIC_POINTS, True
I am afraid it is not possible.
Rafal Gaweda
ducvanvt
Yes it works perfectly. You are a champ!!
