API Panel results
I'm using the following code to extract results from panel nodes. Everything works ok except I'm not able to set the property "smoothing within a panel", and extracted results appear as if "global smoothing" option was selected. How do you change this? Regards,
For j = 1 To panelcoll.Count
Dim obj As IRobotObjObject
obj = panelcoll.Get(j)
Dim panelnum As Long
panelnum = obj.Number
Dim nodes As String
Dim nodesel As RobotSelection
Dim nodecoll As RobotNodeCollection
nodes = obj.Nodes
nodesel = robotapp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_NODE)
nodesel.FromText(nodes)
nodecoll = robotapp.Project.Structure.Nodes.GetMany(nodesel)
Dim FEparams As New RobotFeResultParams
FEparams.Layer = IRobotFeLayerType.I_FLT_MIDDLE
FEparams.SetDirX(IRobotObjLocalXDirDefinitionType.I_OLXDDT_UNDEFINED, 0, 0, 0)
For k = 1 To nodecoll.Count
Dim node As IRobotNode
node = nodecoll.Get(k)
Dim nodenum As Long
nodenum = node.Number
FEparams.Node = node.Number
FEparams.Case = caso
Dim FEresults As RobotFeResultDetailed
FEresults = robotapp.Project.Structure.Results.FiniteElems.Detailed(FEparams)
Next
Next
