API Panel results
API Panel results
alfredmx
API Panel results
alfredmx
I'm using the following code to extract results from panel nodes. Everything works ok except I'm not able to set the property "smoothing within a panel", and extracted results appear as if "global smoothing" option was selected. How do you change this? Regards,
For j = 1 To panelcoll.Count
Dim obj As IRobotObjObject
obj = panelcoll.Get(j)
Dim panelnum As Long
panelnum = obj.Number
Dim nodes As String
Dim nodesel As RobotSelection
Dim nodecoll As RobotNodeCollection
nodes = obj.Nodes
nodesel = robotapp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_NODE)
nodesel.FromText(nodes)
nodecoll = robotapp.Project.Structure.Nodes.GetMany(nodesel)
Dim FEparams As New RobotFeResultParams
FEparams.Layer = IRobotFeLayerType.I_FLT_MIDDLE
FEparams.SetDirX(IRobotObjLocalXDirDefinitionType.I_OLXDDT_UNDEFINED, 0, 0, 0)
For k = 1 To nodecoll.Count
Dim node As IRobotNode
node = nodecoll.Get(k)
Dim nodenum As Long
nodenum = node.Number
FEparams.Node = node.Number
FEparams.Case = caso
Dim FEresults As RobotFeResultDetailed
FEresults = robotapp.Project.Structure.Results.FiniteElems.Detailed(FEparams)
Next
Next
Rafal.Gaweda
Autodesk Support
Autodesk Support
Possible only for FeExtremValue, Maps, and Cuts.
See also:
http://forums.autodesk.com/t5/robot-structural-analysis/export-results-arsa-via-api/m-p/3560764#M649...
Rafal Gaweda
alfredmx
Hello Rafal,
Thanks a lot for your help. I hope this can be added in futures releases, because in Robot "Plate and Shell results" table you have the ability to change "smoothing" property.
