API: NON LINEAR HINGE DEFINITION
StefanoPasquini6790
Advisor Advisor
StefanoPasquini6790
Good Morning Artur and Rafal,
it exist the possibility to definine properties of non linear hinge in excel and assign it to a bar in Robot via API?
Thanks to the lockdown, I'm back to work over PushOver in Robot, and I'm studying a fast way to set up the process.
Thanks in advance, and have a safe and good day.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
rsousa_
Good morning,
The question is not for me, but i think the answer is yes.
I have a similar spreadsheet for non-linear supports and the workflow is basicly the same.
I have non-linear functions for UX, UY, UZ and so on and i've tested the following code:
Private Sub CommandButton1_Click()
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
RobApp.Interactive = False
Dim i As Integer, j As Integer, k As Integer
i = 1
j = 0
Dim aux As Double
Dim myBarRD As RobotBarReleaseData
Dim mylabel As RobotLabel
    Dim mynlm2positive As RobotNonlinearLinkParamsCustom
    Dim mynlm2negative As RobotNonlinearLinkParamsCustom
    Dim mynlmCS As RobotNonlinearLinkParamsCustomSegment
    Dim myNLM As RobotNonlinearLink
Do While Cells(9 * i - 6, 1) <> ""
Set mylabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_RELEASE, "apoio_no_" + CStr(Cells(9 * i - 6, 1)))
Set myBarRD = mylabel.Data
' Direction UX
If Cells(9 * i - 6, 3) + Cells(9 * i - 5, 3) + Cells(9 * i - 4, 3) + Cells(9 * i - 3, 3) + Cells(9 * i - 1, 3) + Cells(9 * i, 3) + Cells(9 * i + 1, 3) + Cells(9 * i + 2, 3) <> 0 Then
    Set myNLM = RobApp.Project.Structure.Nodes.NonlinearLinks.Create(CStr(Cells(9 * i - 6, 1)) + "_UX")
    myNLM.SetCurveType I_NLCT_CUSTOM
    Set mynlm2negative = myNLM.GetParams(2)
    Set mynlm2positive = myNLM.GetParams(1)
    myNLM.SetParams mynlm2negative, 2 'in order to set symetry to false
'    MsgBox myNLM.Symetry
' Define positive values of non-linear diagram
j = 1
For k = 9 * i - 2 To 9 * i + 2
If Cells(k, 3) = "" Then Exit For
    Set mynlmCS = mynlm2positive.New()
    aux = Cells(k, 4).Value * 1000
    mynlmCS.OriginPoint = Cells(k, 3).Value / 100#
    mynlmCS.Expression = aux
    mynlmCS.Constant = False
    mynlm2positive.Set j, mynlmCS
    j = j + 1
Next
myNLM.SetParams mynlm2positive, 1
' Define negative values of non-linear diagram
j = 1
For k = 9 * i - 2 To 9 * i - 6 Step -1
    Set mynlmCS = mynlm2negative.New()
    mynlm2negative.Set j, mynlmCS
    j = j + 1
Next
' assign non linear model to support
myBarRD.EndNode.NonlinearModel.Set I_DOF_UX, CStr(Cells(9 * i - 6, 1)) + "_UX"
RobApp.Project.Structure.Labels.Store mylabel
Else
End If
Dim selectionBars As RobotSelection
Set selectionBars = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
selectionBars.FromText CStr(Cells(9 * i - 6, 2))
RobApp.Project.Structure.Bars.SetLabel selectionBars, I_LT_BAR_RELEASE, mylabel.Name
i = i + 1
Loop
RobApp.Interactive = True
Set RobApp = Nothing
MsgBox ("The End!")
End Sub
In the example it is applying the non-linear model only at end-node and non-linear function for UX but i think you can get the picture. Sorry for the lazzy code...
The result of this code is something like this:
Kind regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @StefanoPasquini6790
According to documentation it should be possible
Good Luck !
Rafal Gaweda
