API Modal Analysis - Eigenvectors and Modal Masses
GGB.BHB
Message 1 of 10
GGB.BHB
Hi
I am currently writing some c# code to extract modal anlysis data based on this post
https://forums.autodesk.com/t5/robot-structural-analysis/api-modal-analysis-results/m-p/5699437/high...
I have two questions
a. Is it possible to extract the normalised eigenvectors rather than unnormalised eigenvectors?
b. Has the API been written yet to extract the modal masses which correpond to the eigenvectors?  Previous posts suggested that this was in the pipeline.
Many thanks
Replies (9)
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dim MS As RobotMassSumServer
Set MS = RobApp.Project.Structure.Results.Advanced.MassSum
Rafal Gaweda
Message 3 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Not implemented in API
So either dump adjusted table or get results as they are and normalize them by yourself
Rafal Gaweda
Message 4 of 10
GGB.BHB
Thanks Rafal
I still think I'm missing the section of code that gets the value of the specific part of the mass sum which represents the modal mass.
e.g. in the following bit of code RDD (of type RobotDisplacementData) is used to extract the values of the eigenvectors.  Is there a similar type to extract the various masses?
Many thanks
Dim RDD As RobotDisplacementData
Dim Nodes  As RobotNodeServer
Dim RES As RobotEigenvectorsServer
Dim REV As RobotEigenvaluesServer
Set Nodes = RobApp.Project.Structure.Nodes
Set RES = RobApp.Project.Structure.Results.Advanced.Eigenvec​tors
Set REV = RobApp.Project.Structure.Results.Advanced.Eigenval​ues
Modalcase = 3
NModes = RobApp.Project.Structure.Cases.Get(Modalcase).Mode​sCount
row = 1
For I = 1 To Nodes.GetAll.Count
    NodeNumber = Nodes.GetAll.Get(I).Number
    For Modenum = 1 To NModes
        Set RDD = RES.Value(NodeNumber, Modalcase, Modenum)
        Cells(row, 1) = Str(NodeNumber) + " / " + Str(Modalcase) + " / " + Str(Modenum)
        Cells(row, 2) = REV.Value(Modalcase, Modenum).Frequence
        Cells(row, 3) = RDD.UX
        Cells(row, 4) = RDD.UY
        Cells(row, 5) = RDD.UZ
        row = row + 1
    Next Modenum
Next I
Message 5 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example code:
[A9].Value = RobApp.Project.Structure.Results.Advanced.MassSum.Current(13, 9).UX ' cur mass ux
[B9].Value = RobApp.Project.Structure.Results.Advanced.MassSum.Current(13, 9).UY  ' cur mass uy
[A10].Value = RobApp.Project.Structure.Results.Advanced.MassSum.Current(13, 10).UX ' cur mass ux
[B10].Value = RobApp.Project.Structure.Results.Advanced.MassSum.Current(13, 10).UY ' cur mass uy
[D9].Value = RobApp.Project.Structure.Results.Advanced.MassSum.Total(13, 3).UX
[E9].Value = RobApp.Project.Structure.Results.Advanced.MassSum.Total(13, 3).UY
[D10].Value = RobApp.Project.Structure.Results.Advanced.MassSum.PartCoeff(13, 10).UX
[E10].Value = RobApp.Project.Structure.Results.Advanced.MassSum.PartCoeff(13, 10).UY
Rafal Gaweda
Message 6 of 10
GGB.BHB
Thanks Rafal,
The masses I was actually after were the Modal Masses mX, mY and mZ.  Is there a call for them or can they be calculated some other way?
Message 7 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dim RS As RobotResultServer
Set RS = RobApp.Project.Structure.Results
Dim ModalCase As RobotSimpleCase
ModalCaseNumber = 71
RS.Any.LoadCase = ModalCaseNumber
Set ModalCase = RobApp.Project.Structure.Cases.Get(ModalCaseNumber)
For I = 1 To ModalCase.ModesCount
    RS.Any.Mode = I
    RS.Any.ResultId = 1767
    Cells(I, 1) = RS.Any.ResultValue
    RS.Any.ResultId = 1768
    Cells(I, 2) = RS.Any.ResultValue
    RS.Any.ResultId = 1769
    Cells(I, 3) = RS.Any.ResultValue
Next I
Rafal Gaweda
Message 8 of 10
GGB.BHB
Brilliant, fantastic!
All up and running,
Many thanks
Message 9 of 10
WALIDGIO
is this code can run for the ROBOT 2025 version ?
Message 10 of 10
Stephane.kapetanovic
yes.
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
