(API) - Meshing panels problem
2 REPLIES 2
vitor_monteiro_ext
168 Views, 2 Replies
Dear forum colleagues,
I am trying to mesh my panels with Coons and 0.05 element size.
However, after running the codes, none of my meshing options are introduced in my FE model. Maybe, I am not getting the panels correctly. Does someone can help me with this issue?
Thank you in advance.
Regards.
Sub MESHING_FEM()
    Dim PanelSel As RobotSelection
    Set PanelSel = RobApp.Project.Structure.Selections.Get(I_OT_PANEL)
    PanelSel.FromText "1 2 3 4 5 6"
    Dim PanelCol As RobotObjObjectCollection
    Set PanelCol = RobApp.Project.Structure.Objects.GetMany(PanelSel)
    Dim obj As IRobotObjObject
    For i = 1 To 6
        Set obj = PanelCol.Get(i)
        obj.Main.FiniteElems
        obj.Mesh.Params.MeshType = I_MT_NORMAL
        obj.Mesh.Params.SurfaceParams.Coons.PanelDivisionType = I_MPDT_SQUARE_IN_RECT
        obj.Mesh.Params.SurfaceParams.FiniteElems.Type = I_MSFET_4NODE_QUADRIL
        obj.Mesh.Params.SurfaceParams.Generation.Type = I_MGT_ELEMENT_SIZE
        obj.Mesh.Params.SurfaceParams.Generation.ElementSize = 0.05
        obj.Mesh.Generate
    Next i
    Set obj = Nothing
    Set PanelSel = Nothing
    Set PanelCol = Nothing
End Sub
2 REPLIES 2
hi @vitor_monteiro_ext
I recommend that you update your object after adjustments and generate the mesh then.
instead of meshing one element after the other, I suggest you mesh them all together. the junctions will be better and your code will be simpler.
Sub MESHING_ALL_FEM()
  Dim RobApp As IRobotApplication: If NotReady(RobApp) Then Exit Sub
  Application.DisplayAlerts = False
  With RobApp.Project.Structure.Objects.Mesh
    With .Params
      With .SurfaceParams
      End With
    End With
    .Generate
  End With
  Application.DisplayAlerts = True
  Set RobApp = Nothing
End Sub
this code can generate a long wait, messages will not be displayed. You can also make sure Excel supports long-running OLE execution
Best Regards
Thank you @Stephane.kapetanovic. It worked smoothly.
Best Regards.
