I would like to write a script in order to select the load type as the screenshot described.
I used the membre "HowCalcul", but the correct load type is not selected.
Can you help me ?
here is my script :
Dim t As IRobotLabel
Dim td As RDimMembDef
Dim tParam As IRDimMembParamsE32
Set t = RobApp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "**Traverse")
Set td = t.Data
Set tParam = td.CodeParams
tParam.LateralBuckling = True
td.HowCalcul I_DMDAHC_LOCAL_USING_CALCULBUCKLING, I_DMDAWOC_3_K0, I_DMDAWOC_AUTO '====>> here is the PB
td.CodeParams = tParam
RobApp.Project.Structure.Labels.Store t
Set td = Nothing
Set t = Nothing
Solved by Rafal.Gaweda. Go to Solution.
I want to creat a mobile load and check paramètre "moment du à l'excentrement"
i don't find it anywhere!!
can you help me
Thank you
